This was the easiest solution I found:
First, use a JSNI call in your main entry class:
private static native void redirectToUrl(String prefix) /*-{
$wnd.location = prefix + “/index.jsp?logoff=true”;
This assumes you have a standard java servlet container log in
Then you call the jsni method inside your onModuleLoad method with a timer:
logoutTimer = new Timer() {
public void run() {
redirectToUrl(GWT.getHostPageBaseURL));
logoutTimer.schedule(60000*SESSION_TIMEOUT_IN_MINUTES);
You also have to have a declaration for logoutTimer and SESSION_TIMEOUT_IN_MINUTES in the declaration section of your class
Leave a Reply
